Skip to main content
This version of GitHub Enterprise Server will be discontinued on 2025-06-04. No patch releases will be made, even for critical security issues. For better performance, improved security, and new features, upgrade to the latest version of GitHub Enterprise Server. For help with the upgrade, contact GitHub Enterprise support.
Configuring SAML single sign-on for your enterprise
You can control and secure access to your GitHub Enterprise Server instance by configuring SAML single sign-on (SSO) through your identity provider (IdP).
Who can use this feature?
Site administrators can configure SAML SSO for a GitHub Enterprise Server instance.
About SAML SSO
SAML SSO allows you to centrally control and secure access to your GitHub Enterprise Server instance from your SAML IdP. When an unauthenticated user visits your GitHub Enterprise Server instance in a browser, GitHub will redirect the user to your SAML IdP to authenticate. After the user successfully authenticates with an account on the IdP, the IdP redirects the user back to your GitHub Enterprise Server instance. GitHub validates the response from your IdP, then grants access to the user.
After a user successfully authenticates on your IdP, the user's SAML session for your GitHub Enterprise Server instance is active in the browser for 24 hours. After 24 hours, the user must authenticate again with your IdP.
With JIT provisioning, if you remove a user from your IdP, you must also manually suspend the user's account on your GitHub Enterprise Server instance. Otherwise, the account's owner can continue to authenticate using access tokens or SSH keys. For more information, see Suspending and unsuspending users.
Supported identity providers
GitHub supports SAML SSO with IdPs that implement the SAML 2.0 standard. For more information, see the SAML Wiki on the OASIS website.
GitHub officially supports and internally tests the following IdPs for SAML. For more information about the IdPs that are supported for SCIM on GitHub Enterprise Server, see Configuring user provisioning with SCIM on GitHub Enterprise Server.
  • Microsoft Active Directory Federation Services (AD FS)
  • Microsoft Entra ID (previously known as Azure AD)
  • Okta
  • OneLogin
  • PingOne
  • Shibboleth
For more information about connecting Entra ID to your enterprise, see Tutorial: Microsoft Entra SSO integration with GitHub Enterprise Server in Microsoft Docs.
Username considerations with SAML
GitHub normalizes a value from your external authentication provider to determine the username for each new personal account on your GitHub Enterprise Server instance. For more information, see Username considerations for external authentication.
Configuring SAML SSO
You can enable or disable SAML authentication for your GitHub Enterprise Server instance, or you can edit an existing configuration. You can view and edit authentication settings in the Management Console. For more information, see Administering your instance from the web UI.
Note
GitHub strongly recommends that you verify any new configuration for authentication in a staging environment. An incorrect configuration could result in downtime for your GitHub Enterprise Server instance. For more information, see Setting up a staging instance.
  1. From an administrative account on GitHub Enterprise Server, in the upper-right corner of any page, click .
  2. If you're not already on the "Site admin" page, in the upper-left corner, click Site admin.
  3. In the " Site admin" sidebar, click Management Console.
  4. In the "Settings" sidebar, click Authentication.
  5. Under "Authentication", select SAML.
  6. Optionally, to allow people without an account on your external authentication system to sign in with built-in authentication, select Allow built-in authentication. For more information, see Allowing built-in authentication for users outside your provider.
  7. Optionally, to enable unsolicited response SSO, select IdP initiated SSO. By default, GitHub Enterprise Server will reply to an unsolicited Identity Provider (IdP) initiated request with an AuthnRequest back to the IdP.
    Tip
    We recommend keeping this value unselected. You should enable this feature only in the rare instance that your SAML implementation does not support service provider initiated SSO, and when advised by GitHub Enterprise Support.
  8. Optionally, if you do not want your SAML provider to determine administrator rights for users on your GitHub Enterprise Server instance, select Disable administrator demotion/promotion
  9. Optionally, to allow your GitHub Enterprise Server instance to receive encrypted assertions from your SAML IdP, select Require encrypted assertions.
    You must ensure that your IdP supports encrypted assertions and that the encryption and key transport methods in the management console match the values configured on your IdP. You must also provide your GitHub Enterprise Server instance's public certificate to your IdP. For more information, see Enabling encrypted assertions.
  10. Under "Single sign-on URL," type the HTTP or HTTPS endpoint on your IdP for single sign-on requests. This value is provided by your IdP configuration. If the host is only available from your internal network, you may need to configure your GitHub Enterprise Server instance to use internal nameservers.
  11. Optionally, in the Issuer field, type your SAML issuer's name. This verifies the authenticity of messages sent to your GitHub Enterprise Server instance.
  12. Select the Signature Method and Digest Method dropdown menus, then click the hashing algorithm used by your SAML issuer to verify the integrity of the requests from your GitHub Enterprise Server instance.
  13. Select the Name Identifier Format dropdown menu, then click a format.
  14. Under "Verification certificate," click Choose File, then choose a certificate to validate SAML responses from the IdP.
  15. Under "User attributes", modify the SAML attribute names to match your IdP if needed, or accept the default names.
Further reading
